Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-22-2009, 11:09 PM
posiman's Avatar
posiman posiman is offline
Exclamation 86 camaro irocz
i have a 86 camaro irocz thats fuel injected and it will not start. if i put starting fluid in it, it will run til its all gone there is fuel in the tank but no reading on the gauge on engine. also doesn't smell like fuel near the MAF censor where the throttle is. and if i try to start it without starting fluid in it and press gas down seems to die more. also just replaced fuel pump and filter.
Old 11-23-2009, 05:27 PM
iroc343 iroc343 is offline
Re: 86 camaro irocz
I'm assuming this is a tuned port injection engine. First thing to do is check for fuel pressure at the fuel rail and let us know what it is. Be careful with the starting fluid, you'll put a rod out with that stuff.
Old 11-23-2009, 08:50 PM
posiman's Avatar
Re: 86 camaro irocz
the thing is that there is no reading on the fuel pressure gauge. i fixed the fuel pump because it was backwards. but it starts up and then dies instantly. and the gas pedal still seems like a kill switch. when it starts up in the begining and i give it gas it dies.
Tags
camaro , issues , starting
