Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-22-2009, 08:01 PM
piperflying piperflying is offline
Sunoco Fuel
A 94 CVPI can it use high octane , 50/50- Sunoco/92 octane ? Would I change plugs ?
Old 11-23-2009, 10:20 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Sunoco Fuel
No changes are necesary.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-24-2009, 08:39 AM
Re: Sunoco Fuel
Thank's Way
Old 11-27-2009, 02:37 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Sunoco Fuel
Understand that there is no valid reason to run any octane higher than 87 with a stock engine configuration. If the engine is pinging/knocking, a higher octane can be used but is just masking the underlying problem temporarily.
If you want to gain more performance by using higher octane, simply using the higher octane will not work. Spark timing must be advanced to take advantage of it - something I just recently had some fun playing with on my car
By the way, 87 octane provides MORE energy than the same volume as another octane. Therefore without an appropriate spark timing, you are PAYING MORE for LESS MPG.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 11-30-2009, 11:19 AM
Re: Sunoco Fuel
Thank's Blue
Old 07-18-2010, 05:19 PM
jnslick's Avatar
jnslick jnslick is offline
Re: Sunoco Fuel
i hate to disagree, but in my 95 if i run 87, it sucks it down like crazy, but as soon as i fill it up with 92 i can go for days, i also noticed it runs better as well, although i'm sure this could be one of those case by case situations, but just wanted to get my 2 cents in here
Old 07-19-2010, 09:44 AM
Re: Sunoco Fuel
Then there is an underlying problem with your vehicle. Maybe your cylinders have a good amount of carbon build up increasing the compression ratio enough to cause minor detonation (ping/knock). Or maybe your HO2s need replacing.
