Old 11-22-2009, 10:25 AM
offshore1 offshore1 is offline
83 350 won't start
tuns over got spark and fuel but won't start any ideas?
Old 11-22-2009, 10:39 AM
Scrapper Scrapper is offline
AF Premium User
Re: 83 350 won't start
have you pulled any of the plugs out to see if there wet with gas? if not i'd look at one or two of them because if your getting gas and spark it should start. is the spark yellow or blue?
Old 11-22-2009, 11:17 AM
i pulled the #1 plug it seemed dry. the spark is yellow
Old 11-22-2009, 12:28 PM
pulled another plug it's wet
Old 11-22-2009, 12:41 PM
AF Premium User
now i'd do compress check then if one was wet. was it gas or oil on plug? but you need a blue spark maybe coil going bad.
Old 11-22-2009, 12:45 PM
AF Premium User
thats got the hei distrib in it don't it? if so you might try changing coil or rotor button but sounds like coil.....good luck...
Old 11-22-2009, 12:56 PM
thanks for the info i will give a try.
Old 11-22-2009, 01:21 PM
j cAT j cAT is offline
Thumbs down Re: 83 350 won't start
the yellow spark means the ignition module is bad. this mounted at the base inside the distributor fails with normal useage around 175 ,ooo mi. the failure however will be sooner if there is any arcing in the high VoltAGE WIRES/CAP...
Old 11-22-2009, 04:11 PM
thanks
