Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-22-2009, 01:52 AM
jamesmetairie jamesmetairie is offline
91 ciera spilling coolant=
1991 ciera,3.3 litre ,only about 30,000 miles(cherry). friend,s car. it looks like the coolant spilled outta the resevoir and also outta the rad cap. i tested the car and the fan kicked in at the right time and later kicked off when the motor cooled a bit. probly original thermostat. the plan is to change the thermostat and rad cap and flush the system.
Old 11-22-2009, 10:47 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 91 ciera spilling coolant=
Maybe check the cap? If it can no longer hold the pressure it is rated for it will cause the same problem you are having even if the car has not overheated.
Old 11-28-2009, 06:40 PM
Ronald1 Ronald1 is offline
Yes replace the thermostat and the cap, and also make sure you fill it according to what's in the repair manual, so that no air enters the system.
__________________________________________________ _________________________________
I owe my life to holistic healthcare practitioner Naomi Elizabeth Shuchter. You were right Naomi Shuchter, acupuncture is not just hogwash for sissies
