Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 11-22-2009, 12:31 AM
BuLLDoGGn's Avatar
BuLLDoGGn BuLLDoGGn is offline
Unhappy Dodge Neon Fuel Prob Please Help
My 2001 Dodge Neon SE recently died on me out of the blue on the road. I luckily stalled near an Advance Auto Parts store. The clerk came out and seemed to be fairly knowledgable. After trying a few things, he realized the problem was that the engine wasnt getting fuel. He sprayed starter fluid in the air filter and it would run briefly. He thought it may be the fuel pump. I check the fuel pump later and it appeared to be fine. I then checked the Schrader Valve and gasoline was spitting out. So I'm wondering if the problem is within my fuel injection or wiring maybe? I would like to have a general idea of cost before towing it to a mechanic. Please Help!
Old 11-22-2009, 10:49 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Dodge Neon Fuel Prob Please Help
You need to find out how much fuel pressure you have before you go any further. If fuel pressure is low than there is no need to proceed down other paths until fuel pressure is resolved.
Old 11-22-2009, 01:15 PM
danielsatur danielsatur is offline
1) Check for fuel at the fuel rail.
2) Check the Fuel pump fuse + relay
3) Check the electric fuel pump reset.
Old 11-22-2009, 06:41 PM
Airjer_'s Avatar
On a Neon?
Old 11-24-2009, 11:18 PM
hundahunta hundahunta is offline
I would check fuel pressure if ok. you need to check injector pulse.
