Noise from hitch under trailer
When I put on hitch on my 2002 ezt tb, even if it sits all the way inside and the spring pushes the rod against the fixing bolt, it still shakes a few millimiters around. This doesn't effect safety, I hope, it just makes a boring noise during travelling especially with light trailers. Suggestions??
Thank you! |
Re: Noise from hitch under trailer
Mine does the same thing, it makes noise when driving over bumps no load on the hitch, normal.
turn the stereo up
2002 LT Trailblazer 4x4 One of the first of this kind on the road 2003 3500 LT Silverado 4x4 ext cab 2006 Heritage Softail HD FLSTI |
Funny, other cars don't do it at all, this is so loud. This hitch is made by a drunk engineer then I guess. I'll turn stereo up!!
Different trailers take different ball diameters. The diameter is stamped on top of the ball. Look at your trailer manual for required size.
Check bolts for tightness at the frame and the hitch ball nut. |
Yes it can drive a person nuts. If so do something to fix it. If in the tubing where it fits into reciever weld it up a little on sides with a select fit. If in the pin install a large pin tkat fits tight. If in the ball and trailer hitch check ball for proper fit and hitch for and hitch for adjustment. Sometimes driving a shim into where the loseness is helps. Let us know how it goes. Good Luck
The ball size is fine, it's the hitch itself that shakes into his seat on the car. I live in Italy, our hitches usually are really tight or bolted to the car, this is really weird. It "snaps" inside but it is not fix. Does exist an external thing to hold it better? I have seen somewhere a square tube cut with a bolt that works as a vice between hitch & car... never seen?
In the end, I drill and tap a vertical hole in the square tube holding the hitch. When I install it I also tight a bolt with a counter-nut to hold the hitch down and no noise anymore!! Cheap and quick.
Thanks |
You also could have wrapped the hitch end with duct tape so that it fit snugly into the receiver. Hitch makers frown upon any modifications to their equipment for fear you might weaken it in the wrong place. Offhand, it doesn't sound like you drilled into a critical spot, but please beware of the fact and tow safely.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Right, even I was afraid to drill in a weak place but I tell you it is not. It is such a tick steel, it won't break. It doesn't really work where I put this bolt, it's right at the end of the receiver.
By the way, it's a modification and if something goes wrong, it wouldn't be nice! Thanks |
