Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 11-20-2009, 02:05 PM
walker12 walker12 is offline
96 Cavy 2.2L 5speed.
Im looking at buying a 96 cavy 2.2L 5speed this weekend how ever the engine needs some work done to it. i was wanting some input from people that have done work on a cavy and i want to know what i have to do to make this engine stand runing about 5000 to 5500 RPMs.
my intentions on using this car is for racing in the 4cyl class and i want to know what i can do to help the performance without braking the bank.
also what is the most common problem in the 2.2L that you have come across
Old 11-20-2009, 10:13 PM
wafrederick wafrederick is offline
Banned
Re: 96 Cavy 2.2L 5speed.
1997 and down 2.2s are inteferance engines when the timing chain breaks,not caught in time and the valves do bend.2.2s do have problems with timing chains breaking.Once in a while head gasket,leak out the left front corner.
Old 11-21-2009, 08:22 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
that is also the case for the 2200s, made between 98-01/02ish
after reading here for 4 years, i would say the most common problem with the engine itself would be the head gasket
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-21-2009, 11:31 AM
Banned
1998 and up 2200s are not interferance.Every timing chain job I have done on a 1998 and up,no valves bent so far.Another thing with the 2.2,it is cheaper to fix over the 2.4 quad 4 which is more expensive to fix when it breaks.
Old 11-26-2009, 07:08 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
I've never heard of one of them snapping their timing chain however.
if your looking for power, don't look at the 2.2 OHV motor. Its best used as a daily driver from point a --> b and saving gas.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-26-2013, 12:05 AM
ole hornet driver ole hornet driver is offline
Well, not sure what you're racing, on circle track, the old 2.2L hangs in there, but the Honda's and Fords, and a couple of Toyota's are a little bit of a challenge, work on you're handling first, only way I keep up is I outhandle them Know the 2.2 and2.4 eccotech are hot, but spendy, am guessing this is your first year of racing, best advice is put it back into good mechanical shape, learn from it, save up some money and put your knowledge, and savings together to get faster the next season. Racing is a lot of fun, but like everything else ya gotta crawl, before you can walk, ya gotta walk before you can run, then after that the checkbook controls everything
