Old 11-20-2009, 10:02 AM
jenboaz85 jenboaz85 is offline
how do i remove a shifter cable
the shifter cable for my 95 pontiac grand am is overstretched and needs to be replaced. i cannot change gears because the shifter just wiggles. it is a manual trans, 6 cyl. also, i have found a shifter cable at a junk yard from a 95 grand am, manual trans. 4 cyl, will it work for my car.
Old 11-22-2009, 01:10 PM
3100 3100 is offline
Banned
Re: how do i remove a shifter cable
welcome to forum, did you try adjusting the cable. Look under the hood at the cable you should see locking button, there you can make some adjustments I believe.
Old 11-22-2009, 10:55 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF jenboaz85 !
You sure about the V6 manual trans ?
Ive not seen any but 94 and under Guess someone could have swapped it.
Any how as 3100 stated thiers a lever on top of the trany that releases the cable, I do not think they are ajustable.
They should be auto adjusting, if its realy lose, probly needs replaced.
1999 Grand Am SS 3.4 OHV
