Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-19-2009, 11:03 PM
vando002 vando002 is offline
03 Explorer 4.0 L P2270 Code
Hi All,
I just bought a 2003 Ford Explorer last night with 73k on a 4.0L Eddie Bauer edition. After driving it around for a little bit, the CEL came on (of course, not during the test drive!). I checked it and the code was P2270 O2 Bank 1 Sensor 2 Signal Stuck Lean. I believe this was right after I filled it up with gas. Anyone have any guidance on this? Should I replace the O2 sensor? If so, which sensor is this? Thank you!
Adam
Old 11-20-2009, 01:19 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 03 Explorer 4.0 L P2270 Code
The sensor is the one behind the converter. I believe you only have one converter. If by chance you hace dual exhaust, it is on the passenger side behind the converter.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 12-20-2009, 02:21 PM
I don't have dual exhaust, but I went under the truck and I don't see any O2 sensor beyond the catalytic converter or the muffler. I see two sensors on the Y pipe before they come together but that's it. Are there 2 small catalytic converters on the Y pipe? That's what they look like. The code again in Bank 1, sensor 2. Is bank 1 the driver or passenger side? The truck is an Eddie Bauer Edition if that helps.
Thanks.
Old 12-20-2009, 02:59 PM
way2old's Avatar
TOKEN HILLBILLY
Bank 1 is passenger side.
Old 12-20-2009, 06:12 PM
Thanks, I got it changed. I didn't realize that there were two catalytic converters on this truck. All four O2 sensors look fairly accessible which is good to know for future knowledge. Thanks for your help!
