Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-08-2003, 09:41 PM
2k2whitemaxi 2k2whitemaxi is offline
Question Problem with hood ????????????
OK now on the driver side of my HooD .. the hood is lower then the fender . But on the passanger side they are perfectly even . I have gotten my headlights stolen 3 TIMES ( and i was wondering if u guys think it was the bodyshop that made it uneven or is there something under the hood i can do ????//
Does anyone have any suggestions
thank you
Old 04-08-2003, 09:55 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
who have u pissed off to have ur headlights stolen 3 times?
Old 04-09-2003, 03:20 PM
WoW do u not know anything about a 2002 maxima headlights they are the hottest item stolen on the streets right now.. So its not that i pissed anyone off u idiot.... its not my fault nissan made it so easy for them........So b4 u talk think about wat u are gogint o say .....PEaCe
Old 04-09-2003, 03:29 PM
well try gettin the 2000 lights and replacing them and then you wont have all the thugs in NJ jackin ur lights :finger:
Old 04-10-2003, 08:53 AM
Strider Negro's Avatar
Strider Negro Strider Negro is offline
Send a message via ICQ to Strider Negro Send a message via MSN to Strider Negro
stop arguing this is getting childish
It probably could have been the mechanic who put your headlights but one never knows
this is just my opinion
Old 04-10-2003, 02:54 PM
tdaily tdaily is offline
There should be a large rubber screw at each corner of your hood where the hood meets the fender, just behind the headlights. These adjust up and down to control the exact line your talking about. If screwing these up and/or down doesn't correct the problem, then either one of two things has happened. Either your hood has been slightly bent or the headlight is out of adjustment. You can correct your hood by grabbing the corners, one with each hand, and push one corner up, while pulling the other one down. Just don't use too much pressure because it doesn't take much at all. Keep doing this until you've pushed it back into place. If its your headlight that is out of whack the only thing to do is loosen the bolts that hold it in and see if you can adjust it. Just make sure that before touching the headlight that it is out of alignment with more than just the hood, i.e. the bumper, grille, etc... If you have never wrecked the car then there isn't much of a reason that the headlight shouldn't be straight and its more likely the hood. But if you find it to be the headlight and loosening the bolts that hold it in won't allow you to straighten it, then the only way to get it perfect is to remove it and make the bolt holes larger so that you can move it in the desired direction.
By the way: I agree with StRider, the kiddie angst posts should be taken elsewhere. Posts that provoke arguments should be ignored, or taken to some Nickelodeon forum.
