Old 11-19-2009, 07:28 PM
young_11_blood's Avatar
young_11_blood young_11_blood is offline
vibration in rear end.
1997 chev c1500 i had a real bad vibration in the rear end so i replace the carrier bearing and u joints. the vibration is less than before but it starts at around 60km/hr and increases at higher speeds. i can feel it throu the pedels and slightly in the stearing wheel could a tire be outa ballance or is my diff goin. it doesnt houl. it used to befor i replaced the u joints. Any ideas would be great. thanks
Old 11-19-2009, 08:49 PM
Re: vibration in rear end.
my e-brake cable is hangin. like its extremely loose. so is it possible that my brake is on. causein it to vibrate.
Old 11-20-2009, 08:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Vibrations at 55-60 MPH is usually tires and wheels.
Any noise besides vibration?
E brake usually does not vibrate.
To check for E brake cabble sticking jack it up in rear and apply brake and then release it and see if you can turn wheels by hand without drag.
MT
Old 11-20-2009, 10:38 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Swap the tires front to rear and see if the vibrations transmit through the steering wheel. If so it's defintely the tires.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-20-2009, 10:43 AM
there is no noise. in the cold this mornin it seemed to hesitate once i put it in gear. should i get the trans. flushed while im at it.
Old 11-20-2009, 11:09 AM
MT-2500's Avatar
AF - Advisor
No on flush.
You can flush up more problems than you flush out.
How many miles on transnission and when was last filter service done.
How is fluid level and fluid condition?
MT
Old 11-20-2009, 11:17 AM
237000 the fluid is dirty but no metal in it. and i havent replaced the filter and not sure when my dad did last. its been a long time
Old 11-20-2009, 11:57 AM
MT-2500's Avatar
AF - Advisor
With that many mile it is dangerous to do anything to it.
Is fluid level good hot in park?
I would just check filter and not even use much new fluid.
MT
Old 11-20-2009, 12:17 PM
so the truck shifts fine once warmed up. and i jacked the truck up the noticed the driver side brake was rubbin. so i took the tires off and hit behind the drum hopin to free them up. now the vibration isnt as serious.
