Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-19-2009, 12:43 PM
heymanz heymanz is offline
95 olds still stalls need more help
ihave changed fuel filter cleaned the throttle body and all parts on it have unplugged the tps and test drove it an still stalls have unplugged the egr an road tested an still stalls after the car is driven over a half hour in town traffic it will stall sometimes it starts back up or may take a few tries sometimes it runs an stalls other times it runs ok after stalling i would apprecate any more advice thanks.
Old 11-19-2009, 09:18 PM
moscow913 moscow913 is offline
Re: 95 olds still stalls need more help
Tough problem. Just out of curiosity, when's the last time the alternator output has been checked? Working properly, correct voltage output?
Old 11-19-2009, 10:14 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Also, test the fuel pressure. There is a fitting to install a tester on the fuel rail above the intake manifold. The pump may be giving out
Old 11-21-2009, 11:10 AM
yes i checked the charging its at 14.2 volts with headlights n fan on high im trying to get a lone of a fuel pressure guage will check when i find one yhanks for your imput
Old 11-29-2009, 09:23 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Any DTC's, or are we just guessing here? Many things can cause a stall, but all are related to lack of ignition, or fuel supply. Typically, ignition problems will set a DTC, but fuel delivery problems (pressure) will not show up, thats where the pressure gage comes in handy. When it stalls and will not start back up, check spark!
Old 12-01-2009, 08:43 AM
yes i have finally got a loan of a fuel pressure tester could tell me what pressure is ok for my car thanks
Old 12-01-2009, 02:59 PM
12/1 idrove the car about a half hour to warm it up i stopped and hooked up the fuel peassure tester it idled for 5 min or so then stalled out it was holding 40lbs of fuel pressure ihad it scanned they said a security key code this cars key has a chip init i went to a locksmith he said the chip seems ok he said it would not start if it was bad and after it stalls it starts right back up hard to check forspark would appreicate more advice thanks
Old 01-02-2010, 08:52 PM
dfoliver dfoliver is offline
You may be in luck here (so to speak). I just had this problem on my '95 LSS (Normally aspirated). It is the Engine Control Module (computer). Did just exactly what yours is doing EI. takes 2 - 6 tries to start, may die after driving a few feet - could just up and die while driving down the highway! Make sure that the wiring is not broken going to-or-from the ECM before spending the bucks on the ECM though.
BTW, if you have an aftermarket ECM on the car now, it will NOT show codes so don't depend on them unless you have a GM unit on it. RockAuto Parts sells ECMs from around $200 - $300.
Hope this helps.
Old 01-03-2010, 10:55 AM
thank you for your reply dfoliver. can you tellne where the computer is located on my car.
Old 01-03-2010, 02:25 PM
Attached to the firewall where the toes of your front passenger's feet would be (on the '94). I expect it's the same location on the '95.
Go to a local junkyard and pull one from a '95. Make sure it's the same computer that's on your car. Easy enough to pull out, and cheaper than 2-300 dollars that's for sure.
Old 01-03-2010, 05:47 PM
moscow913 is right on the money. Best of luck. BTW moscow913, how much does the junkyards demand for an ECM?
Old 01-04-2010, 12:30 AM
I picked up two of them (just in case) for 30 bucks each. But the K.C. area has a "pick & pull" where you can do it yourself. No hi-tech, no 'professional' high prices.
Old 01-04-2010, 01:52 PM
Cool. That sure beats the price I just received via a voice mail quoting $260 for a reman' (part only). The replacement procedure looks easy - 2 power connections and looks like 3 color=coded pinned connections. Thanks again.
Old 01-25-2010, 06:07 PM
thank you dfoliver it finally warmed up a little to go to local u pullit auto yard ifound a computer there it cost me $30 when i pulled it out i found that it was a rebuilt unit i installed a week and a half ago now it runs fine i would like to thank all of you who gave me input on my problem . thank you heymanz.
Old 01-26-2010, 01:27 PM
Jrs3800 Jrs3800 is offline
Glad you got This Fixed...
This is a very common failure mode for all of the C, H and U Body 3800 Powered 1994 & 1995 Models... The majority of these PCM's will fail in that manner.. They almost never fail completely, just enough that it can leave you chasing your tail..
Been there and done that several times over with my 95's... My 95 van is updated to the 97 PCM for this reason, and my 95 Bonneville is currently being updated to the 97 PCM as well..
