Old 11-19-2009, 11:21 AM
bulrid8 bulrid8 is offline
Interior light problem
Anyone ever dealt with the interior lights blinking on and off? Mine will do it, driving down the road or sitting still.
Now the weird part is, I can hit the steering wheel and they will stop. This is the courtesy lights only. No dash lights affected.
Any thoughts?
Old 11-19-2009, 12:12 PM
tomj76 tomj76 is offline
Re: Interior light problem
The GEM is located under the instrument panel, to the right if the steering wheel. It controls the courtesy lights based on in puts from the door switches and the interior light switch on the instrument panel. The lights also turn on when the key is turned off.
It could be a door switch, but it might be the I/P switch or the GEM itself.
Is the problem limited to the courtesy on the doors and under the I/P, or do the dome lights come on also?
Old 11-20-2009, 01:35 AM
This is mainly just the dome lights that are going crazy. I thought about a door sensor, But why would it stop when you hit the steering wheel?
Old 11-20-2009, 07:40 AM
fy171 fy171 is offline
i have the same problem 2002 van when the lights go on i pull on the keys in the in the Ignition switch and it goes out, spray a little lock grease in it
Old 11-20-2009, 12:55 PM
I will try some graphite in the ignition cylinder and see if that helps.
Thanks
Old 11-20-2009, 06:47 PM
smata67 smata67 is offline
I had same problem, noticed that I could stop it by jiggling the ignition key switch. Sprayed the keyhole with the small blue can of graphite lubricant. Hasn't happened since.
1999 Windstar SEL
