Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-18-2009, 11:14 PM
skwerlabusr skwerlabusr is offline
Exclamation Quick Squeal!
help! when i start my mustang cold or for the first time in a couple hours it will have a slight screech or squeal only for a few seconds while starting. I have already tried replacing belt tensioner pulley and the timing belt. About to get the starter pulled and tested. Perhaps it is the plunger of the starter that drives the flywheel not retracting and causing a grind? Well maybe we can figure out with this audio i have recorded:
squeal.mp3 - 0.30MB
squeal2.mp3 - 0.25MB
Old 11-20-2009, 12:32 AM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
Re: Quick Squeal!
You don't by chance have the A/c on? If no then it sounds like the Bedix gear in the starter.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 11-21-2009, 10:41 AM
Re: Quick Squeal!
Oh no not at all. It's getting very cold here in Michigan
Old 11-21-2009, 11:03 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Quick Squeal!
I think it's the Bendix on the starter causing the squeal. When it's cold the grease gets thick and retards the retraction on the Bendix. I'd take the starter off and clean the Bendix drive and relube it with some white lithium grease.
Old 12-10-2009, 01:53 PM
tedhontz tedhontz is offline
Re: Quick Squeal!
I may be taking a stab in the dark, but could it be the alternator? I had a different vehicle that had an alternator squeal and they rebuilt the bushings/bearing/pulley and the noise went away. Also, in the cold the noise was worse.
Tags
cold , noise , squeal , starter
