Old 11-18-2009, 10:24 PM
bigbird90650 bigbird90650 is offline
2001 Buick Lesabre new ignition reprogramming help.
My neighbor just bought a 2001 Buick Lesabre that someone tried to steal. They slammed the ignition. He just bought another ignition on ebay and I'm going to help him install it. I was wondering how to reprogram the ignition cause I'm sure it has PassKey security. Can you give me specific simple instructions to reprogram this ignition? Thanks a lot.
Old 11-19-2009, 12:41 PM
maxwedge maxwedge is offline
A990 racer
Re: 2001 Buick Lesabre new ignition reprogramming help.
It does have passkey, what part are you replacing the key cylinder?
Old 11-20-2009, 12:04 AM
We are replacing the key cylinder for sure and maybe the ignition switch too. My neighbor bought a whole used steering column on ebay so that we would have all the parts that we need. We haven't taken it apart yet though to see the extent of the damage. Is there a reprogram that we can do at home without taking it to the dealer? Thank you so much.
Old 11-20-2009, 06:30 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Sorry, but you would need a Tech II scan tool to program.
Old 11-20-2009, 07:56 AM
A990 racer
You could try the PK relearn first. Turn the key on leave it on for 10 minutes ( battery connected of course.). Remove key, then repeat the process 2x more, this may allow the system to relearn the new key.
Old 11-20-2009, 12:06 PM
Here you go. No Tech II needed.
http://www.bsecorp.com/files/techtips/ST9303l.pdf
Old 11-20-2009, 12:10 PM
I found the programming info. You can relearn most GM cars and trucks. Here's the link. Maybe it should be a sticky in the forums. Great information.
Old 11-20-2009, 12:11 PM
Thanks Maxwedge. Here is the link to the programming instructions.
Old 11-20-2009, 06:31 PM
A990 racer
I was close, my info worked on my 2003 Lesabre, good find and yes there should be a link to this in the forum.
Old 11-20-2009, 09:43 PM
HotZ28's Avatar
AF Moderator Elite
We have suggested using the relearn procedure here for several years; however, the problem is, sometimes it works & sometimes it don't!
