Old 11-18-2009, 09:26 PM
hoosierdaddie hoosierdaddie is offline
idle
88 accord 5 speed,carb, at cold start it idles very high(2600)and smokes alot(white)smells like gas.after it warms up it idles so low it tries 2 die and does sometimes.any ideas would b appreciated thx and oh by the way...GO COLTS lol
Old 11-26-2009, 02:26 AM
Xaisk Xaisk is offline
Re: idle
Haha that brings me back. I got the same engine and had the same issue minus the smoke. however when adjusted in some crazy unproper way, it caused white smoke to come out, prolly not a good thing.
What im getting at is your carb sounds like it needs to be adjusted. There is a black plastic screw looking thing that adjusts the idle RPMs. Also you can use the throttle cable hex bolts to set the idle speed with that too.
Another adjustment is on the top near the carb flap. mine was a gold colored flathead screw. That adjusts how much fuel you let into the carb.
I wouldn't touch that, but I thought I should throw that out there in case you wanted to know.
Mine was sitting for a long time so I took the carb out of the engine and cleaned it up using a rebuild kit. It works great now minus a new problem involving fuel tank pressure I believe.
