Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-18-2009, 08:58 PM
kurtis68 kurtis68 is offline
94 cutlass suprem 3100 keeps losing spark
94 olds cutlass suprem keeps losing spark I replaced crank, cam sensers, icm, replaced. Ecm. If I unplug the eltrical wires into the icm plug them back in the car starts and its been cuting out idles high sometimes if I unplug throtale postion senser it idales down and smoths out plug back in runs fine it can last mints or days don't know what to do with it
Old 11-19-2009, 12:44 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 cutlass suprem 3100 keeps losing spark
This could be a pcm issue, try tapping the pcm when this occurs see what happens, also look for corroded conections at the pcm.
Old 11-20-2009, 09:42 AM
I trade taping the pcm and check all wire conters. The will run for minets some time days befor losing spark when it loses spark the icm never loses power to it. It cranks over for a while before it starts
Old 11-20-2009, 11:54 AM
A990 racer
Was this the original problem?
Old 11-21-2009, 01:11 PM
The original problem is car keeps losing spark I found a bad pigtail replaced it but it missies will idaling and when u pull out
