Old 11-18-2009, 07:06 PM
84hurst 84hurst is offline
1994 Jimmy 4x4 Problems - 4hi inop
Well, I searched for 40 pages and cannot seem to find a solution to my problem. The link that I've followed a few times is only for 1998 and up and will not apply to my problem. I own a 1994 GMC S15 Jimmy with the 2 button switch on the left side of the dash. The truck will not engage 4hi at all, not in any gear, not moving, not standing still. 4lo works great, but sometimes both 4hi and 4lo lights light up when engaged. When I push the 4hi button, I can hear the transfer case making a noise (I assume the motor is attempting to engage 4hi). Both the 4hi and 4lo lights will flash a few times but with no 4x4 engagement. I checked for codes and found none. I checked the accuator under the battery but I'm not sure if it is good or not. I am able to move it by hand approximately 1/8-1/4. Is this normal or it supposed to move more? I've heard that its possible for the cable coming off the accuator to seize up but I would like to know for sure. There is vacuum at the accuator, so I do not believe there is a vacuum issue here. Are there any common problems, describing my exact symptoms, that I can look into? Thanks in advance. Jeff
Old 11-18-2009, 10:29 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: 1994 Jimmy 4x4 Problems - 4hi inop
The electronic transfer case on the 93 and up with the dash button are essentially the same as the newer ones. In your case and from what you describe, check you transfer case control motor and its connections. These units have a habit of having corroded connections and making them not work properly. If that checks out it could very well be the control unit located inside the truck. These can and do go bad causing problems too.
Old 11-18-2009, 10:45 PM
Where is it located? I will look into it when I get back into town. Any particular wires I should look at that normally get corroded?
Old 11-18-2009, 11:10 PM
blazes9395's Avatar
Newbie mod
The transfer case control module is located on the passenger side of the dash, located under the glove box if I remember correctly. I think it piggy backs the ECM wich is located in the same spot, under the passenger side dash.
I would check the control motor first, maybe take it off the transfer case and clean it and make sure it looks clean. Check the connector too and clean it if need be and see what happens and go from there.
Old 11-19-2009, 10:17 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
When it does not shift right how many time does the shift button light blink?
MT
Old 11-19-2009, 11:07 AM
MT-2500's Avatar
AF - Advisor
Grounding pin J on diagnostic connector should give a code if not shifting right.
Codes range from 1 -2 -3 and 4.
Post back code no if you cam get code.
And post back transfer case ID on back of transfer case.
MT
Old 11-19-2009, 12:35 PM
The light blinks about 5 times I believe, but I'm out of town at the moment and won't be able to verify this til next week. As for the transfer case, I would assume that all the 94 GMC Jimmy's with the push button 4x4 will be the same. 233 I believe. I already tried to pull the codes and there were none stored.
Old 11-19-2009, 02:40 PM
MT-2500's Avatar
AF - Advisor
ID the transfer case.
And recheck for codes.
4 light blinks could be code 4.
Ther is no code 5 on them
MT
Old 11-19-2009, 08:10 PM
The light blinks about 5 times when when I try to engage 4hi, not when I'm trying to pull codes.
Old 11-20-2009, 08:16 AM
MT-2500's Avatar
AF - Advisor
Pull codes and post back what you get.
MT
Old 12-01-2009, 02:42 PM
Well, finally got back to town and am working on the truck right now. There is a number 2 code stored. As I figured, this is the 233 tranfer case.
Old 12-01-2009, 03:19 PM
MT-2500's Avatar
AF - Advisor
Code 2 points to shift/encoder motor fault.
Check all wiring to it and if wiring is good you will need to replace the encoder motor.
I would suggest a factory repair manual or a All Data online sub for the wiring diagrams AND REPAIR FLOW CHART FOR CODE 2.
http://www.alldata.com/products/diy/index.html
LET US KNOW HOW IT GOES.
MT
Old 12-01-2009, 03:54 PM
It seems I need a subscription to alldata? Is there a step by step guide to determining the exact cause instead of buying a repair guide for $30? I'm laid off right now and don't really need to spend $ I don't have.
