Old 11-18-2009, 05:14 PM
Kashmoney Kashmoney is offline
96 Blazer Problem Need Some Help Before That Snow Comes Please!!
I have a 96 Blazer that I had done the lower intake on. After reassembly I had to re set the timing marks and such. I have no SES light on or anything, but the truck makes like a knocking or poping sounds and follows with idle. I put new cap rotor plugs wire oil coolant in. Just wondering if maybe I'm a tooth off or something.
Old 11-18-2009, 06:22 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 Blazer Problem Need Some Help Before That Snow Comes Please!!
Flat top new style dist?
http://files.automotiveforums.com/ga...hp?photo=51302
And be sure to check firing order.
And camshaft retard setting after you get it running.
Let us know how it goes.
MT
Old 11-18-2009, 10:41 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
It does have a horizontal distributor, or enhanced ignition system, follow MT's link to make sure you have the distributor back on right.
Also, make sure the wires are on properly. It is very easy to cross them and casue you to pull your hair out....
Old 11-27-2009, 10:46 AM
ok. Well I have it running but it's still knocking. Would the camshaft retard make it knock or pop.
Old 11-27-2009, 10:54 AM
MT-2500's Avatar
AF - Advisor
What did it take to get it running?
Deep knock would be piston noise or rod and main bearings.
Can you change knock by pulling one plug wire at a time?
Just.
Poping can be plug wire crossed or missfire.
Recheck firing order and dist cap and rotor.
MT
Old 11-27-2009, 10:57 AM
ok thanks. It doesnt seem like a deep knock but more of a poping noise. I thought it was maybe the injectors poping. Since it wasnt knocking before I changed it, I wouldnt think that I spun a bearing because soon as I started it up it was making the sounds. But I am going to recheck it now then I'll repost.
Old 11-27-2009, 11:37 AM
old_master's Avatar
Advisor/Moderator
Old 11-27-2009, 01:58 PM
ok doubled checked wires, tried the 1 tooth ahead and 1 back and it threw codes and was a little harder starting up. So I put it back to TDC rotor pointed at number 1 like I had it started right up but still has that noise there. any other suggestions.
Old 11-27-2009, 03:47 PM
MT-2500's Avatar
AF - Advisor
Knocking or popping noise?
Can you change noise when you pull one plug wire at a time engine running?
MT
Old 11-27-2009, 04:17 PM
I tried pulling one wire a a time but it had no effect it still makes the noise
Old 11-27-2009, 05:09 PM
MT-2500's Avatar
AF - Advisor
You may need to find a mechanic type person with a trained ear to listen to it.
We can not hear noise so you you have to decribe it to us.
Knocking or poping or clicking noise?
Is the noise deep in engine or on top?
MT
Old 11-28-2009, 02:12 PM
Well I hooked it up to a scan tool. Checked all data. Came out with cam retard at 0 degress everything else looked good but was just wondering what the spark is suppose to be at it said 20-26 degress. Its still knocking and other suggestions would be helpful.
Old 11-28-2009, 03:05 PM
MT-2500's Avatar
AF - Advisor
Spark advance is computer controled.
We hear you when you say it is kocking.
BUT????????
What kind of a knock?
MT
Old 11-28-2009, 04:51 PM
I really don't know what kind of knock kind of sounds like a lifter but it don't have that like clinky sounds like a lifter. I am going to try and post a video for some extra support thank you everyone for your help. Would maybe a vacum hose cause it to knock in some way.
Old 11-28-2009, 05:21 PM
MT-2500's Avatar
AF - Advisor
No On vacumn line.
A nock is something lose or broke.
Try to feel or listen for what area the noise is coming from.
Good luck
MT
