Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 11-18-2009, 11:01 AM
SUPERDAVE22 SUPERDAVE22 is offline
1994 e-350 van
HAVING TROUBLE DIAGNOSING BRAKE ISSUE, HAS NEW MASTER CYLINDER AND BLEED BRAKES, BRAKE PEDAL SLOWLY GOES DOWN AND BRAKE LIGHT COMES ON ANY IDEAS AS WHAT TO CHECK NEXT. NO BRAKE FLUID LEAKS THAT ARE EVIDENT. NEED HELP!!!!!!! THANKS
Old 12-06-2009, 07:15 PM
Davescort97 Davescort97 is offline
Escort guy
Re: 1994 e-350 van
You need to bleed the master cylinder. Crack open the front and rear lines and apply pressure to the brake pedal until you get a good pedal. If the system is applying an unequal amount of pressure between the front and rear lines the brake light will come on. I suggest bleeding the front line until the light goes out.
