Old 11-16-2009, 06:53 PM
alejmr alejmr is offline
Engine stops while on the highway
Hi all,
I have a 99 intrugue 3.8.... that being said, While I was driving last week on the highway at 60mph the engine all of the sudden stopped, had to put it in N and turn it on....turned on no hassle but it's scary..... I changed all sparkplugs, wires, gas filter, air filter and oil, went fine for 2 days but then today while on the highway the engine shut off by itself, again put on N, cranked and started fine..... any thoughts? no code though, the SES if off....
Old 11-17-2009, 12:08 AM
dizzle1's Avatar
dizzle1 dizzle1 is offline
Re: Engine stops while on the highway
Was the electrical working when the engine shut off or could the fuel have stop flowing after the change of the fuel filter? And how many miles does your intrigue have?
Old 11-18-2009, 08:43 AM
Hi,
Thanks for the reply; yes, the electrical was working when the engine shut off, this also happened before the whole tune up was made and after, also yesterday.... BTW the car has 100000k (miles)
Old 11-19-2009, 10:42 AM
Hi all, just an update, the car shut off yesterday again, same symptoms, my mechanic told me it might be the cranckshaft sensor.... I don't want to get ripped off.... any suggestions?
Old 11-19-2009, 11:52 AM
dtownfb dtownfb is offline
it very well could be the crankshaft sensor but the check engine light should come on if the crankshaft sensor is giving you this much problem. Another possibility is a bad ignition switch which would not throw a code.
Old 11-19-2009, 03:10 PM
Tobey Tobey is offline
If it was the crankshaft position sensor it would definitly be throwing codes and the engine would be quite hard to start.
At those speeds the engine should start again by just leaving in drive and pressing the accelerator. The fact that you have to turn the key makes me wonder if it isn't the ignition switch as well...
Old 11-19-2009, 06:02 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
A failing crankshaft position sensor doesn't always throw a code. In my experience I'd actually say they usually don't throw a code.
In this case though, I'm thinking it could be a bad ignition switch. A bad crankshaft sensor usually doesn't allow the engine to start right away after stalling.
Furthermore, when the engine stalls the hydraulic pressure is lost in the automatic transmission regardless of how fast you're going. So simply turning the key off and then back on will not restart the engine like it would with a manual transmission.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 11-19-2009, 07:15 PM
Ok I took it to my mechanic guy and he tried to change the sensor but he could not extract the pulley that is just before to get into the sensor.
Now the funny thing is that when driving back home the car kinda make a slight stall sign but instead of the engine stopping, it threw the code P0336.
Or it could be something else?
Any suggestions?
That makes me think that it is indeed the sensor, but I need to make sure.... please heeeelp!
Old 11-19-2009, 10:28 PM
Ah, you're right. Suppose you'd need an output shaft driven pump to do that.
Old 11-20-2009, 10:21 AM
I would put mine into neutral and re-start it. The first time mine stalled, scared the s**t out of me. After that, I stayed calm, shifted to neutral and re-started in a matter of seconds.
Old 11-23-2009, 10:34 AM
Hi Guys,
Do you have any other ideas?
the SES light went off now (please read below)...
It has not stalled since.
Any suggestions?
Old 11-23-2009, 02:28 PM
I did a quick Google search on P0336. this relates to the crankshaft position sensor. Changing the sensor should resolve the problem. Of course, if the light went out, you may want to wait a bit until it gives you trouble again.
Old 11-29-2009, 11:53 AM
rhaigh08's Avatar
rhaigh08 rhaigh08 is offline
Send a message via AIM to rhaigh08
In my experience the engine light does not stay on for certain things but if you lugged it in to read the codes it would still spit the code because it's still in the computers memory until you reset it. I'd try scanning for codes again and if it still comes up that code replace that part..
Old 11-29-2009, 11:55 AM
rhaigh08's Avatar
Also check the battery cables for corrosion and clean them if neccessary.
