my generator light stays on and the gauge doesnt read 14 volts but the battery dosent go dead
Re: 1996 jeep
Use this simple test to determine if you fault lies in your battery or alternator. Always test the battery directly using a volt meter.
Battery test: with engine off battery should be no less than 12 VDC Alternator Test: with engine running battery voltage should be above the reading you had with the engine off or around 13VDC If battery test fails and alternator test passes= bad battery ( take battery to autozone for a load test) If battery test passes and alternator test fails= bad alternator ( take alternator to autozone for a load test) If both fail= take battery and alternator to autozone for load test
1993 Jeep Cherokee Country 4.0, 2WD, 200K+ miles 2007 Ford Expedition XLT 4X4 |
