Old 11-16-2009, 04:51 AM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
41 willys coupe street rod 1:25 revell
Is the 41 WILLYS COUPE STREET ROD 1:25 REVELL a good kit to buy. I always liked the shape of the Willys coupe but I wanted to know some things about the kit. Some questions:
  1. Is the molding accurate
  2. Does the kit fit well together
  3. Is the kit easy to lower or customise
  4. Do the doors open
  5. Does the bonnet come off
Thanks,
F.C
or
Old 11-16-2009, 02:04 PM
Twowheelsrule Twowheelsrule is offline
Re: 41 willys coupe street rod 1:25 revell
Thanks,
F.C
1 The body looks like a Willys and I have not heard any complaints.
2 The kit fits very well and easy IMO. The rear suspension is a little tricky to get glue securely but, will work fine with otherwise.
3 You will have to cut the frame to lower the car or you can buy "Perrys Resin" frame that is lowered and made for a bigger engine and wider tires.
4 The doors do not open but, there was an much older Rev. willys that did have opening doors.
5 The engine hood does come off. It has molded clips on the sides that don't look realistic but, when painted they are not offensive.
If I have time I will post some pictures of my box stock build.
Mark
Old 11-16-2009, 02:59 PM
