Old 11-15-2009, 08:26 PM
Didymus Didymus is offline
Clear Tubing Source?
I need some flexible clear plastic tubing for the fuel hose on the Fujimi 1/24 356 Speedster I'm building. I'd like to get an assortment of sizes so I can have some on hand. Is there a source for this stuff?
Thanks!
Ddms
Old 11-15-2009, 08:47 PM
Porsnatic Porsnatic is offline
Re: Clear Tubing Source?
You can you use ths tubing from Model Factory Hiro, it gives plenty to make a couple of models. Good luck!
Old 11-15-2009, 09:05 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
In 1/24, it's really impossible to tell whether small dia clear line is tubing or if it's solid. So happily things like monofilament fishing line or sewing thread look just as good.
Or...
You can take a straight section of clear sprue several inches long, and gently melt the center with a flame. Carefully pull the ends apart, and you have your own styrene monofilament. You can make it to whatever diameter you need by varying how fast you pull.
Paint it with transparent clear colors if desired, or with clear flat for a translucent look.
PHOTOBUCKET SUCKS
Old 11-15-2009, 10:36 PM
klutz_100's Avatar
stretched clear heat shrink tubing sa,e way as stretched sprue. makes any size diam you want.
Old 11-15-2009, 11:16 PM
Great ideas. I'll try stretching some clear sprue, since I don't have any clear shrinkfit tubing around the house.
(That L25 looks great, Klutz. Is it 1/20?)
Old 11-15-2009, 11:41 PM
klutz_100's Avatar
Originally Posted by Didymus View Post
(That L25 ... Is it 1/20?)
It's the same kit as yours. The Tamiya 1/20. Build HERE
Recommend stocking up on some of the shrink tubing - it's a very useful item to have on hand.
