Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-15-2009, 07:22 PM
Sonic Eclipse's Avatar
Sonic Eclipse Sonic Eclipse is offline
Send a message via MSN to Sonic Eclipse Send a message via Yahoo to Sonic Eclipse
Auto to Manual - Reverse lights don't work!
Yeah its me again. Solved the speed sensor problem, but now I've got another.
When I shift into reverse the reverse lights don't come on.
Am I missing something?
- 1995 Eagle Talon TSi AWD
- 1996 Eagle Talon ESi - 5spd (RIP) -_-
- 1994 Eagle Talon ES - 5spd (sold)
- 1997 Eagle Talon TSi AWD (sold)
- 1990 Nissan 300zx TT (RIP)
Old 11-15-2009, 07:59 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Auto to Manual - Reverse lights don't work!
Did you attach the reverse light harness?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-15-2009, 08:09 PM
This is probably a stupid question, but where is that located?
Old 11-15-2009, 08:54 PM
david-b's Avatar
Dave is THAT guy
You have a N/T right? If you open the hood and look right at the front of the tranny, it sits right in front.
Best pic I can find really. You can see the connector for it on the far right
75 Monte Carlo
Old 11-15-2009, 09:29 PM
Yeah its non-turbo
I've found the connector, but what do wires on the connector connect to?
The one write up I found on 2gnt says to wire the Reverse Sensor to the Park/Neutral switch. If thats the case which one of the plugs are the Park/Neutral switch?
Old 11-15-2009, 11:16 PM
david-b's Avatar
Dave is THAT guy
If the car was auto before then it's not going to have the connector that.
Not sure on the new connector though. Sorry dude.
75 Monte Carlo
Old 11-15-2009, 11:45 PM
Never mind man, I found the problem, Reverse lights are working.
Thanks though.
Old 11-15-2009, 11:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
What was the problem?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-16-2009, 12:30 AM
It was like the write up on 2Gnt said.
The two wires on the Reverse sensor had to be wired to the Park/Neutral Connector.
The car that was used in the write up was for a 95, which uses two separate computers, one for the trans and one for the motor. 95 is the only year where they did this for some reason. 96-99 uses just one computer, and on my car (96+) the Park/Neutral connector and Transaxle range switch connector are both one switch, where as the 95's are two separate connectors.
It took me awhile after looking over the plugs to figure that out.
But now the reverse lights are working as they should.
Old 11-16-2009, 10:00 AM
david-b's Avatar
Dave is THAT guy
Cool cool. Glad it's working now.
75 Monte Carlo
