Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-15-2009, 01:24 PM
davepk74 davepk74 is offline
Send a message via Yahoo to davepk74
car dies and starts right back up
I was driving from southern illinioi sto chicago down i-55 and on occasion my 1999 nissan maxima would just die as i am driving, it would start right back up again and then it would die after about 20 minutes , there are no warning lights on or anything. I tried to run it on the scanner but it didnt tell me anything, and i even monitored the 02sensors and all that other stuff.
If anyone can help or give me a suggestion it would be great.
Old 11-16-2009, 02:29 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: car dies and starts right back up
No single sensor has the 'right' to shut down the engine, but will cause SAFE MODE =2k2 rpm ceiling. Shutdown needs at least two simultaneous sensorfailures, normal IGN ON -warning lights will come ON...
However, MAF can hang the system (=nostart). Disconnecting will bypass it, cause safe mode.
No warning lights sounds like total loss of power; check all wiring/fuses/fusible links coming from batt to ign switch (replace it).
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 11-17-2009, 10:46 PM
rather_b_boatin rather_b_boatin is offline
Possible intermittent failure of the fuel pump, however more often than not a fuel pump is like a light bulb, works or is broken. Put fuel pres. guage on fuel rail, run into spot where you can see while driving. Keep an eye on Volt guage when "die" occurs, may point to electrical prob. like Nahk describes? Do headlights die too?
