Old 04-08-2003, 06:24 PM
Lyall Lyall is offline
Send a message via ICQ to Lyall
1996 Caravan Windshield wiper removal.
I'm having trouble popping off the wipers. Is there a special technique or tool to make this job as simple as it should be?
Old 04-10-2003, 12:12 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Are you trying to remove just the wiper blade or the entire wiper arm?
Old 04-10-2003, 05:47 PM
The whole wiper arm...
It's sitting on a splined shaft -- and I was wondering what the technique is to pry it off?
Old 04-10-2003, 06:00 PM
Polygon's Avatar
The Red Baron
There should be a little lever on each arm that you pry open with a flat head screwdriver. Then with some persuasive back and forth movement you should be able to get it off.
