Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-14-2009, 11:23 AM
panozracing's Avatar
panozracing panozracing is offline
Fuel Cell Collectors
I just got a new fuel cell bladder from fuel safe. Its the pro cell (Unlike the sportsman that came with the GTS). The pre-installed fuel pickup is just a hose with a sq. fabric filter on the end jambed into the passenger rear corner.
The sportsman bladder had a plastic collector with ball check valves installed in the center back of the cell.
What gives? Should I take the collector from the old bladder and make it work in the new one or go with the pickup the factory installed?
factory std. pickup:
http://www.fuelsafe.com/store/parts-...its/fp181.html
collector:
http://www.fuelsafe.com/store/parts-.../st100-10.html
since the collector is $150 bucks and the std. pickup is about $50 I would think the collector is an upgrade?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-14-2009, 11:53 AM
Jim woodruff's Avatar
Jim woodruff Jim woodruff is offline
Re: Fuel Cell Collectors
collector:
You are correct the box with the check valves is an up grade and you want it in your new fuel cell.
Old 11-14-2009, 05:57 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
thats really odd Brian, my WC Car came with the collector -not quite sure about the bladder.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 11-14-2009, 06:12 PM
I confirmed that the collecter is the way to go. Its installed and the car is almost ready for RA in 3 weeks....WOOT....knock the dust off...who's coming?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-15-2009, 07:19 AM
You need to install the collector in the front of the cell in the middle. This is to fill it under hard braking and the middle for side to side fill. Cut the foam to hold it in place. The return hose should be way below the fuel level on the bottom and NOT into the collector. This will prevent static electricty and keep the fuel cool and prevent vapor lock. I had to redo mine since I did it wrong the first time.
Old 11-15-2009, 02:32 PM
well....I dont have a return line (only fuel injected cars have returns) and I already installled it in the middle back. Figure it would fill under acceleration....thats where they were in the old cells for 9 years and never had a problem. thanks for the input.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 11-15-2009, 07:03 PM
GTS#25's Avatar
GTS#25 GTS#25 is offline
Brian,
I need to replace mine as well.
Were you able to remove and install the bladder without removing body panels ?
Doug
Old 11-15-2009, 07:04 PM
gosborne gosborne is offline
Since you have it already installed it doesn't matter much but, Jim's right, you have more forward transfer under (hard) braking than under acceleration giving you the best chance to load the collection box.
Gary O.
Panoz GT-WC #11 (build in progress)
74 Porsche 911 IROC replica
88 Porsche 944 Cup race car #12 (sold)
Old 11-15-2009, 07:21 PM
Originally Posted by GTS#25 View Post
Brian,
Doug
I removed the entire fuel can and had to loosen body panels and with two people pry the roof panel up and remove the can simultaneously. It was not that difficult. The biggest PITA was dealing with the metal straps and getting them in the can slots without scratching all the nice new paint
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
