Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 11-13-2009, 01:08 PM
charles546 charles546 is offline
Front brake problem
I have a friend who needs some help.
He just bought a 99 cougar which has a brake problem.
Put new calipers and new hoses on it but didnt help.
When you first touch the brakes the steering wheel turns to
the left just a little but the car pulls to the right.there is a little roaring soundat this time.push the brake alittle harder stops fine and straight.any help or advice would be appericated.
Thanks charles546.
Old 11-15-2009, 06:10 PM
rhandwor rhandwor is offline
Re: Front brake problem
Does this car have anti lock brakes it makes a difference on what to look for also does it have any warning lights coming on at this time.
Old 11-19-2009, 07:52 AM
thanks for the reply. it does not have antilock brakesand the brake light is not on.put on a rack and found a little slack in right lower balljoint going to replace it today hope that solves the problem.if you have any advice we sure would appericate it.
thanks again tor trying to help
charles546
Old 11-20-2009, 03:18 PM
Did the ball joint fix the problem or do you still have a problem?
Old 11-20-2009, 06:56 PM
no didnt help. going to get frontend lined to see if that helps just put on new tires.checked the rest of sespention seemed to be fine. just lost on this one.
Old 11-20-2009, 07:32 PM
Put the car on four jack stands. Pull the wheels and watch the calipers. Have someone else push on the brakes. Look at the mounting hardware for the calipers. Are the calipers moving properly. Look at the rotors for signs of rubbing. A bad front wheel bearing can cause problems.
Old 12-18-2009, 07:19 AM
sorry took so long to get back to you. took car and got four wheel alignment took care of the problem. thanks for all the help.
charles
