Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 11-13-2009, 02:24 AM
jrock750reb jrock750reb is offline
tappet clearance
just require tappet clearance for 302 windsor can any one please help
Old 11-14-2009, 11:51 PM
mechhound mechhound is offline
Re: tappet clearance
What year? Have you done recent engine work?
Old 11-15-2009, 02:29 AM
cant give you year but it is pre injection and no there has been no engine work done lately just a bit noisey
Old 11-15-2009, 11:09 AM
It gets a little complicated. There is no adjustment on these per se. You have to get the lifter at the bottom of it's stroke and BLEED IT DOWN, then check the gap between the rocker arm and the valve stem. My Haynes manual shows the gap should be between .091 and .151. If it doesn't fall between there, you have to purchase either longer or shorter push rods. In your case probably longer. I suggest you buy a manual.
Old 11-15-2009, 11:37 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
This is correct for the early'70's through 80's 302 with the pedestal-type rocker arms.
The late '60's through early -70's 302 used adjustable ball-type rocker arms (on studs) like a small-block Chevy.
With these, one tightens the rocker arm, while turning the pushrod. When there is just the slightest drag on the pushrod, one then turns the rocker arm nut another 1/2 turn, then it's set.
Old 11-16-2009, 11:58 PM
thanks guys. just a bit more you are talking in inches arent you? because i live in aus i will have to convert it to millimetres
Old 11-17-2009, 10:54 PM
Yes. Between 91/1000ths of an inch and 151/1000ths of an inch.
Old 11-18-2009, 02:22 AM
thankyou for your help it is greatly appreciated i will let you knoow how it goes
Old 11-18-2009, 10:39 AM
MagicRat's Avatar
If you have to get new pushrods, consider getting the adjustible kind.
Old 11-24-2009, 07:43 PM
Torch Torch is offline
I have always adjusted these by rotating the engine until the push rod I am working on is as low as it will go and then adjusting the rocker so that it is just barely loose, once they are all set up I start the engine and let it warm up then make minor adjustments until everything stops clicking.
