Old 11-12-2009, 10:35 PM
bigginsz bigginsz is offline
02 Caravan Engine PROBLEM!!!
I have a good friend that owns a 2002 dodge caravan. I know it has the 3.0 in it but not much else. Couple of weeks ago it started to run like crap, then it died on the side of the road and would not start. We replaced the wires and plugs ( they were toast ). I thought that was the problem. Nope, still no start. I loaned him my scanner and it pulled out three codes: P0108, P1297, and P0303. We know the P0303 is misfire, that was probably due to the wires and plugs. One was for the MAP sensor, so we replaced it. After that it started up, but still runs like crap. He does have enough money to start replacing parts and I have no idea were to start. If anyone can help.
Old 11-12-2009, 10:50 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 02 Caravan Engine PROBLEM!!!
Can you expand on "runs like crap"? All the time hot or cold?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-12-2009, 10:57 PM
It spits and sputters really bad. Like its missing really bad. I do know its getting a really good blue spark and its getting gas.
Old 11-13-2009, 01:09 AM
hundahunta hundahunta is offline
does the hose at the map sensor have vacuum with the engine running. p0108 map sensor voltage too high, p1297 no change in map from start to run..
Old 11-13-2009, 02:38 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Everything I've read says the 3.0 ltr engine was discontinued in 2000. You must have a 3.3 or 3.8 ltr. If you haven't yet make sure the plug wires are routed correctly and inspect all vacuum hoses for cracks or chaffing. If equipped verify EGR is working and not binding. An EGR valve that's cracked open can cause a healthy vacuum leak. Verify injectors are working by listening for a consistant click with a stethoscope or long screwdriver or connect a noid light to verify PCM pulse.
Old 11-13-2009, 06:58 AM
I'm sorry, it is a 3.3. Were do I find the EGR? Whats the firing order to make sure the wires are correct?
Old 11-13-2009, 08:55 PM
Well I guess I don't have to worry about the problem any more. My friends parents took the caravan to a shop for him. They said it was the number 3 fuel injector. They are going to replace it and clean the rest. Thank you all for your help and I hope this helps any one else with this problem.
Old 11-14-2009, 01:36 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Glad to hear all is well.
