Old 11-12-2009, 07:52 PM
klaasy1 klaasy1 is offline
97 Voyager fuel prob
It will start, barely idle, try to give it gas, it dies... fuel pump or fuel injector?
Old 11-12-2009, 10:47 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 97 Voyager fuel prob
Whats you fuel pressure at?
Old 11-13-2009, 09:53 AM
The fuel pressure is zero.
Old 11-13-2009, 11:20 AM
Airjer_'s Avatar
Sounds like the next step is to make sure there is power at the pump. If that passes time to pull the tank and replace the pump.
Old 11-16-2009, 03:36 PM
Spit Spit is offline
I don't see how it could start at all with 0 fuel pressure. Have you put a fuel pressure gauge on the test point of the fuel rail?. Can you hear the pump running for 2 seconds or so when you to the key to the run (not start) position. If you can hear the pumo running and the fuel pressure is too low.....Have you ever changed the fuel filter? It sits on top of the tank and is a PITA to get to and change, but a restricted filter is a very likely culprit if the pump runs.
Spit
Old 11-16-2009, 10:26 PM
Airjer_'s Avatar
Plugged fuel filters do not cause no starts!
Old 11-17-2009, 07:22 AM
Airjet....I agree with you, but he says it does start...barely runs/idles. If he really has 0 fuel pressure how does it run at all? on air? It obviously has some fuel getting to the engine which means he has to have some amount of fuel pressure
If he wants to eliminate fuel pump/fuel issues...1st step is to check the fuel pressure with a guage. If he has a lean fuel situation it shouldn't it be throwing a check engine light.. P-171? He may off base thinking it's fuel anyway. If he has low fuel pressure and he hasn't changed the filter in a long time that's a good place to start before dropping the tank and changing the pump.
Spit
Old 11-17-2009, 08:37 AM
Airjer_'s Avatar
That's pretty common for vehicles to start and stutter with the little pressure left or built up after a hot soak in the fuel rail after a pump failure. Sometimes you can repeat this several times before it will not start at all.
He states he has 0 fuel pressure. We don't know if the pump can be heard running or not and we don't know if the pump is being supplied with power. Why not take a couple minutes to figure out those 2 things and either condemn the pump or start looking for an electrical failure instead of replacing a fuel filter that will do nothing except leave one frustrated because it didn't fix it. Once the cause of the condition is figured out and repaired than focus on the maintenance items that have may have been neglected.
Old 11-17-2009, 07:19 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
There's a reason why the fuel filter isn't on the scheduled maintenance list.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-19-2009, 07:16 AM
RIP
Why isn't the fuel filter on the scheduled maintenance list?
