Old 11-12-2009, 05:14 PM
gtp'n gtp'n is offline
Headlight switch
The backlighting on my headlight switch looks like it went out. The switch works fine. Is there a bulb behind here that can be replaced? Does anyone know the bulb part number?
Old 11-12-2009, 08:13 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Headlight switch
if your feeling mechanically incliced...you could tear it apart. pretty sure its an incandescent bulb that will need to be solderd.
there is also one on ZZP for $20
https://www.zzperformance.com/grand_...=820&catid=162
Old 11-13-2009, 03:18 PM
I am fine with tearing the switch apart and sodering the bulbs to the board. I had to do this with my climate control a year or so ago. Anyone know what amperage and wattage bulbs they are?
Old 11-13-2009, 11:43 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
my guess is the same as you used in the climat control unit. They will be 12v, maybe 60mA or so.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-24-2009, 03:58 PM
Brent S Brent S is offline
I also plan to tear apart my '99 GTP headlight switch module, to replace the backlights.........hopefully soon.
I will attempt to post pictures.......but, also recommend other to share their experiences with this task.
Thanks!
