Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-12-2009, 03:02 AM
LWheeler78 LWheeler78 is offline
Engine Cuts Out on HARD Right Turns
Strange problem... 420a non-turbo, nothing modded except the exhaust on this car as far as I can tell. I can turn the car left at 40-50mph and fight the normal oversteer into a hard corner. If I try a turn to the rightat speed then the car cuts out. The radio, interior, etc all still work, so it doesnt feel electrical. It FEELS like a fuel cut of some kind, but I cant find anything that would cause a fuel cut under stress while turning in one direction. I guess it could be mechanical somehow, but it really does not feel that way, it just seems like I suddenly lose all power, the nose dives, and a second later it comes back on. If I'm still in the corner, it cuts back out again for a second, then comes back on.
If I take the same corner but do not stay on the throttle it will take the corner fine.
Any ideas? I've checked the wiring from the battery terminals and the ground, nothing is loose on the pigtails or anything.
Old 11-12-2009, 08:39 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Engine Cuts Out on HARD Right Turns
How much gas is in the tank? Sounds like the gas is getting away from the fuel pump while turning and causing the engine to cut out. Fill up the tank and see if it happens again.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-12-2009, 09:53 AM
RicartParts.com RicartParts.com is offline
Fuel pump ? Has the pump been replaced ?
Old 11-12-2009, 05:51 PM
Fuel level is fine, thats what i thought the first time too. may replace the pump and filter tommorow to see if it makes a difference.
Old 11-12-2009, 09:23 PM
david-b's Avatar
Dave is THAT guy
Could be the filter on the fuel pump itself. Might be really dirty and/or have something blocking it. Pull it from the tank and check it out.
75 Monte Carlo
Old 11-13-2009, 09:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I doubt its the fuel pump. I think its going to be very difficult to track down this problem without logging the ECU to see what its doing. It could be the ECU cutting fuel or spark when turning. Or it could be getting starved for fuel, I guess check it out and see if it looks normal or not. I wouldn't be replacing stuff untill you know its bad.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-24-2009, 04:07 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
did you figure this out?
My money is also on the fuel filter.
Old 02-15-2010, 05:26 PM
99grandgt's Avatar
99grandgt 99grandgt is offline
Send a message via AIM to 99grandgt Send a message via Yahoo to 99grandgt
when turning hard right, with the clutch pedal pushed in to the friction point, does the pedal push back out a little? if so, its not a fuel pump issue...
"haze grey and under way!!!"
99 honda odyssey
99 grand prix gt
possibly a g8 gt when i get to cali
Old 02-15-2010, 09:39 PM
Holset powered 420a
Why would you do this? What is this going to tell you. Its not the fuel pump, fuel pumps dont go out like this, they just dont cut on one day. Not cutting out on turns.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-15-2010, 09:41 PM
ned032002's Avatar
ned032002 ned032002 is offline
Not to mention, resurrecting a dead thread.
