Old 11-11-2009, 08:43 PM
302Z28 302Z28 is offline
97 Cav questions
Can the oil pan be pulled in a 97 Cav with the 2.2. If so is it necessary to raise the motor? The engine has well over 200K and I would like to change the bearings - rods & mains
How can the ignition control module that the coils mount on be checked. The car seems to still hesitate occasionally when warm. Could this be heating up and creating problems?
Thanks,
Old 11-11-2009, 10:00 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 97 Cav questions
I believe it can be, but I wouldn't go changing the bearings just because it has a couple hundred thousand miles on it.
The ignition module can be removed and tested (most auto parts stores will check them for free)... the problem is it's hard to test them while hot. That's probably not causing a hesitation, they usually just cut, losing spark to 2 cylinders and making it run very bad. Check the plugs, MAP sensor, TPS, and fuel pressure... all more likely to cause a hesitation than the ignition control module.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
