Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-11-2009, 01:05 PM
Uppity Mike Uppity Mike is offline
(97 5.9 knocks under acceleration.
Hi, My ram 5.9 knocks under acceleration. I've just pulled my plugs and 7 are fine. Back passenger side is covered in soot. I'm sure I've read some where about intake plenum problems in the past. Is this my problem? It's using some oil. Thanks for the help.
Old 11-11-2009, 07:06 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: (97 5.9 knocks under acceleration.
Is the Check Engine light on?
Has the ignition timing been changed or set lately?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 11-13-2009, 10:35 AM
No changes to the timing and no check engine light on.
Old 11-13-2009, 04:03 PM
AF - Advisor
Does the engine miss or go flat under hard acceleration?
Is this after the engine is warmed up?
How many miles is on the engine and how long since a tune-up with new spark plug wires?
Old 11-13-2009, 05:25 PM
jpb53 jpb53 is offline
If you have a library card you can access this.
http://search.ebscohost.com/login.as...ile=autorefctr. I had a little trouble with one word (center) in my search. I forgot in Canada you spell it centre. This has some basic repair gudes but it has the TSB's where you will be able to search for the plenum pan gasket problem. TSB # is 09-05-00. The TSB shows how to diagnose and repair and gives you the torque pattern you have to follow. Timing is not adjustable on your engine. You set the synch signal on the dist. Also look around for the TSB for plug wire reroute.
Old 11-15-2009, 07:55 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Just make sure your spark plug wires are not crossing and touching each other.
Make sure your ignition coil wiring, #8 and #7 wires are routed properly.
Look at this link http://autorepair.about.com/cs/faqs/l/bl654h.htm
