Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-11-2009, 11:50 AM
kmacas kmacas is offline
engine Interchange Info
Can some one please tell me if I can put a 2002 venture engine in a 2003 Venture? They both are front wheel drive . If it can what modifications do I need to do?
Thank You
Old 11-11-2009, 01:17 PM
wafrederick wafrederick is offline
Banned
Re: engine Interchange Info
will fit and does not come out from the top.It comes out from the bottom with engine/transmission still bolted together.
Old 11-11-2009, 01:28 PM
How about the wiring? there are some changes between 2003 and 2002?
I read that there are issues with fuel injectors and that the PCM might need some reprogramming or something.
Old 11-11-2009, 04:53 PM
Banned
The wiring and injectors are the same and the interchange book called a Hollander is sometimes wrong on interchange.That info you read is wrong
Old 12-19-2009, 09:23 PM
lesterl's Avatar
lesterl lesterl is offline
I put an '01 into my '97 and had to swap the injector assembly and take some brackets off old motor for new one...... Otherwise runs like a champ.
Old 12-19-2009, 10:27 PM
The problem was the Flex plate and camshaft sprocket that the camshaft sensor uses to read. I changed boh AND the engine is working great ,
Thanks for replying
Kris
Old 12-20-2009, 06:56 AM
henry10 henry10 is offline
Is there an advantage of using a 2003 engine instead of of 2002? Or it was the one that you could find economically? What happened to the 2002 engine that required you to get rid of it? Thanks. I may be in the same boat myself with the 1999 Venture I just got.
Old 12-20-2009, 07:05 AM
the 99 engine had the crankshaft bearing turn and then the connecting rod made a big whole in the engine The 2004 was a great deal. Only 63000km (40000 miles) for 300 Canadian and I got the whole car also.
