Old 11-11-2009, 06:06 AM
captclit captclit is offline
Code PO401 EGR insufficent flow detected
Have replaced EGR vacuum regulator, verfied that EGR valve holds vacuum, opens and shuts, good vacuum @ the regulator, have voltage @regulator. What am I missing?
Old 11-11-2009, 06:21 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Code PO401 EGR insufficent flow detected
Either the DPFE or carbon built up under the EGR valve in the passages.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-11-2009, 06:39 AM
EGE tube clear in both lines to the DPFE and to the EGR valve. On the DPFE I am showing 5.0 volts on the sig and ref of the harness even when the truck is cold.
Old 11-11-2009, 07:02 PM
wafrederick wafrederick is offline
Banned
DPFE sensor is bad and is a part stocked by most parts stores knowing they are big problem.
Old 11-11-2009, 08:17 PM
transgta transgta is offline
had same problem.was dpfe
Old 11-14-2009, 08:10 PM
dfordski's Avatar
dfordski dfordski is offline
You have to remove the valve to check this.
"Saving the World......One Ford Truck at a Time!"
Old 11-15-2009, 04:29 AM
Turn out to be carbon between egr and throttle body. For which I removed all and cleaned throughly with brake clean and replaced throttle body to intake gasket. Thanks for all the advice.
Old 11-15-2009, 06:33 PM
way2old's Avatar
TOKEN HILLBILLY
Glad you gort it fixed. Thanks for the fix reply.
