Old 11-11-2009, 12:28 AM
cleong cleong is offline
Whining from engine bay when accelerating
Hi guys recently I am hearing a whining sound coming from the engine bay when ever I press on the gas. The noise goes away once I lift off the gas but not right away there is a lag between when I lift off and the sound going away.
The whining is quite noticable above the engine noise especially at low speeds when pressing the gas.
I haven't located where it is coming from and was wondering if you guys had any ideas. I have a 99 with the 3.5 engine.
Old 11-11-2009, 12:39 AM
jd-autotech jd-autotech is offline
Re: Whining from engine bay when accelerating
check for a vacuum leak by spraying starting fluid around the engine while its running and if the idle picks up theres your leak
Old 11-11-2009, 08:23 AM
bsansa bsansa is offline
Remember to use extreme caution when spraying anything flammable around a hot engine bay.
Have you noticed any drivability issues such as shifting, hesitation, etc. Also, check your tensioner pulley or belt.
Old 11-11-2009, 10:29 PM
dosintrigued's Avatar
dosintrigued dosintrigued is offline
Check to see if the power steering reservoir is low.
Old 11-12-2009, 12:15 AM
As far as drivability is concern it is driving just fine.
I will check the power steering fluod levels. Why would this cause a whining during acceleration?
