Old 11-10-2009, 09:19 PM
1978FordF150 1978FordF150 is offline
1978 F150 Rear Parking Light Problems
Just started acting up today... On the rear driver's side brake light, when i brake or put the blinker, it works, but when I turn on the lights it stays off. I already checked the light and it is good. I am not an expert in wiring, but I checked the wiring for hours and could not find anything that did not look connected properly. I don't know if I should order a new rear brake light socket and replace it, or at the end of the day just swallow my pride and take it to a local mechanic. Any suggestions on those who have had similar problems would be appreciated.
Old 11-10-2009, 10:40 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 1978 F150 Rear Parking Light Problems
Sounds like a ground issue.
Old 11-10-2009, 11:20 PM
Thanks, I'll make sure to check that.
Old 11-10-2009, 11:36 PM
jd-autotech jd-autotech is offline
switch yer bulbs just to be sure, and if you have a pigtail for a trailer check for corrotion there in the end that cause all kinds of fun stuff, but you need to check your ground and the brown wire for power going to the light. hope this helps
Old 11-15-2009, 07:42 PM
Torch Torch is offline
I had a 1977 F-250 a while back, it had a bad ground somewhere at the back end of the truck that caused some problems with the turn signals and hazard flashers, once the ground was fixed the problems went away, sorry I'm not more help it was several years ago.
