Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-10-2009, 06:30 PM
1991rscamaro 1991rscamaro is offline
91 camaro idling high
I have a 91 camaro rs with a 305 (5.0L) throttle body injection that is idling at 1700 rpm. I have replaced the tps and the iac, cannot find any vacum leaks, the check engine (dummy) light is not on. The butterflies are closing all the way, could an intake gasket leaking cause it to idle this high ? Any suggestions would be appreciated. Thanks
Old 11-10-2009, 10:11 PM
classic_327 classic_327 is offline
Re: 91 camaro idling high
a leaking intake gasket could do just that, check it by spraying a little choke cleaner around the edges of the intake, if the motor pitch changes its leaking.
Old 11-11-2009, 05:54 PM
I'll try that and see what happens thanks for the help.
