Old 04-08-2003, 04:32 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Exclamation Need an answer quick
Im ordering some stuff in a few minutes and have whats probably a real stupid question. Im getting spark plugs for my ZC and dont really know if I need to get them for a 88-91 civic or an 89 integra... Or if theres even a difference... Thanks for the help.
Old 04-08-2003, 05:28 PM
91civicDXdude's Avatar
89 integra is your safest best, though i dont know it makes any difference.
Old 04-08-2003, 05:30 PM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
well my D16A9 was the same as a ZC and i could get plugs for that and that was in a civic so i reckon they should be the same
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 04-08-2003, 10:40 PM
*bump*
Old 04-08-2003, 10:45 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
Parts List Reference:
-Alternator Belt: 88-91 CRX
-A/C Belt: 88-91 CRX
-Timing Belt: 1988 Prelude 2.0 Si
-Engine Mounts: 88-91 CRX
-Thermostat: 88-91 CRX
-Crank Seal: 89 Integra
-Rear Main Seal: 89 Integra
-Cam Oil Seals: 89 Integra
-Valve Cover Gasket: 89 Integra
-Radiator Hose Upper & Lower:
1984 Accord - Top (must be trimmed)
88-91CRX-Bottom
-Exhaust Gasket: 89 Integra
-Water Pump: 89-91 CRX
-Oil Filter: 88-89 Integra or 88-91 CRX
-Spark Plug Wires: 1989 Integra. You can get aftermarket. The CRX
plugwires sit about 1" off the valve cover.
-Throttle Body & TP Sensor: 1989-91 CRX or 1988-89 Acura Integra with
the D16A1 engine
-ECU (OK): 1989-91 CRX/Civic Si PM6
-ECU (Better): 1988-89 Integra PG7
The part number may vary depending on the year.
-ECU (Best): 1989-1991 ZC PM7
-Spark Plugs: 88-89Integra or 88-91 CRX <------------ Here
-Head Gasket: 89 Integra
-Intake Gasket: 89 Integra
-Exhaust Header: 88-91 CRX/Civic
-Oil Pan Gasket: 88-91CRX/Civic
-Cam Angle Sensor: 88-89 Integra
-Distributor: 88/89 Integra
-Distributer Cap:
1988-89 integra
1988-91 civic si
-Distributer Rotor:
1988-89 integra
1988-91 civic si
-Clutch/Pressure Plate:
1988 civic/CRX if using 88 tranny (21 splines)
1989-91 civic/CRX if using 89-91 tranny (20 splines)
* 89 Clutch disk Size (7-7/8 inches)
* 90-91 Clutch disk Size (8-3/8 inches)
Old 04-08-2003, 11:04 PM
You rock Seth
Old 04-08-2003, 11:12 PM
Banned
Originally posted by 91civichatch2571
You rock Seth
:jump:
Old 04-08-2003, 11:15 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what about the ls ecu, how would that run the motor ? pr4 ecu. someone told me that the ls ecu runs the zc the best, even better than jdm zc ecu
Team Lonely Drivers
Old 04-08-2003, 11:42 PM
Banned
It will do a fine job, it will NOT do a "better" job than the PM7, but it will do an equal job... Also, you have to running OBD1 to use iether of those ECU's However there is more aftermarket support, like Hondata and so on, but I dont think its worth the OBD1 troubles... IMO.
Old 04-09-2003, 12:44 AM
GTA's Avatar
GTA GTA is offline
Whee..
pr4 is for a b-series aint it? i know a 89 ls ecu is one people use...the pg7 but a pm7 wuold be better than that.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-09-2003, 12:46 AM
Banned
Yea, you can use the B18A and B18B ECU's for the ZC if its a OBD1 ZC... Spoposably they work well too
Edit: Stupid me, the B18A IS OBD0
Old 04-09-2003, 12:47 AM
GTA's Avatar
GTA GTA is offline
Whee..
ahh i see...
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 04-09-2003, 12:48 AM
Banned
OBD1 ZC's came out of the 90-92 Civic/crx's and the 90-96 Civic Ferio
