Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-10-2009, 11:25 AM
sentoyang's Avatar
sentoyang sentoyang is offline
fuel pump not working...
so heres my problem...
i recently changed the fuel injector on my 91 gsx with evo 9's injector.
they are rated at 550 cc vs my stock 450 cc.
with just the injector installed, the car ran well. But when i switch out the fuel pump with the evos (190 lph) the gas seem to be cut off at about 5000 rpm, so my car just halts or seem like it looses all power. I though maybe the evo fuel pump was broken so i ordered a brand new walboro 255lph pump.
before it arrived, i tried swtiching the fuel pump from my 3000 gt (180lph) and since the two car share the same old gen. fuel pump it was a perfect fit... again it had no power at 4500 rpm... just before the 16g turbo kicks in.
now the new pump arrives... installed it, same thing. reach 4500-5000 rpm and the engines seems like it lacks gas. I decided to install the new
pump in my 3000 gt and it works perfect.
so what is wrong with my car? is it the evo 9 injectors? i mean they are like brand new (less than 1000 miles) or do i have to boost the psi before installing the fuel pump. My stock fuel pump is 100lph. I'm at a lost.
any help would be much appreciated . thanks.
91 GSX in process of becoming EVO KILLER
Old 11-10-2009, 12:32 PM
Tal92on Tal92on is offline
Re: fuel pump not working...
Are you using the stock MAF? the evo inejectors are 560cc's, they work very with minimal tuning with the 2g MAF's
Old 11-10-2009, 01:20 PM
ned032002's Avatar
ned032002 ned032002 is offline
Does it feel like your hitting a wall at 4500k rpms? Does it feel like you should be pulling your teeth out of the steering wheel, is that the kind of fuel cut your getting?
Old 11-10-2009, 01:24 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
What are you tuning with? You cant just stick bigger injectors in your car and not pull out fuel or your goin to run rich. Also how much boost are you running?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-10-2009, 01:25 PM
ned032002's Avatar
Your probably running rich as hell and the ecu is cutting fuel to save itself.
Old 11-10-2009, 01:48 PM
sentoyang's Avatar
as of right now... the only thing i have install is a big 16 turbo, kn filter with open vent, greddy bov (without recir.) evo injectors.
everythig else is stock.
when i hit 4500-5000 rpm, my car feels like it runs out of power... similar to the furl cut when you go above the redline.
Old 11-10-2009, 03:04 PM
Holset powered 420a
Wow no wonder the car runs like shit. First recirculate your bov. You are making the car run worse because you are loosing metered air from the system. This is making you run rich everytime that BOV releases air.
Now for the second problem. You CANT run larger injectors without some type of fuel management. The ECU thinks you are still running 450s and is giving the motor way to much fuel. Now the ECU will pull out fuel via the fuel trims but it is limited to only take out so much. Your fuel trims are what fine tunes your car to get the best gas milage. It used the 02 sensor to monitor the air fuel ratio of the motor and then leans/riches up the mixture to a set AFR. You have now maxed out your fuel trims with the ECU trying to lean out the mixture. Yes you may be idleing right at stoich but the ECU can no longer pull anymore fuel out if it needs to. And you will run even richer at WOT. I suggest you put the stock injectors back in till you get some type of fuel management. SAFC at the very least.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-10-2009, 07:32 PM
ned032002's Avatar
Man you've got to do a lot of searching before you start upgrading things. You had to of thought that your problem lies with having no kind of fuel management? Good luck and keep us updated. Check out DSMlink, it's the biggest bang for your buck in my opinion and I still don't have it all figured it out yet. There's a guy on the ecmtuning forums that's selling his 1g Link setup for a pretty decent price considering what it costs to buy new. I can try to find the link if your interested.
Old 11-12-2009, 01:26 PM
sentoyang's Avatar
yes i am interested...
heres a link http://www.extremepsi.com/store/cust...&page=1&veh=1G DSM
so i have to buy one o0f these guys?
Old 11-12-2009, 02:27 PM
Holset powered 420a
Yea, thats exactly what you need. I would get a used one off ebay for about half that price. The SAFC2 are even cheaper, its just the version before the NEO. Both work about the same.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Tags
fuel , gsx , injector , pump
