Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-08-2003, 03:11 PM
92teggsr 92teggsr is offline
blowin' black smoke
I was racing a friend of mine today (he drives a bmw320) and beat him....I know they're not that fast.... but anyways afterwards we pulled into a gas station and he told me that my car was blowing black smoke out of the exhaust whenever i really got on it. Any clue what the reason could be ? He said dirty injectors but I don't know. The car runs fine at least as far as I can tell. Anyone have any ideas ?
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 04-08-2003, 03:18 PM
GSR GSR is offline
Send a message via AIM to GSR
black smoke = rich, unburnt fuel
if it was white smoke youd be fucked
looking for a 95+ 240sx in/near D F Dub area
Old 04-08-2003, 03:25 PM
So what do I have to do ? I know my Ignition timing is advanced pretty far. Should I just retard that or what else could it be ? Is it possible that my injectors could cause that if they're dirty? Would some of that injector cleaner stuff you pour into your gastank help in that case ?
Oh and what would be wrong if it was blowing white smoke? Just curious ? I guess I didn't pay enough attention in automechanics....
99 Honda Civic Si
Stage 2 Clutch
SPP Exhaust
Short Shifter
Eibach Suspension
17's
91 Honda Accord LX
Old 04-08-2003, 03:42 PM
PilotMojo's Avatar
PilotMojo PilotMojo is offline
GSR-
Like actual white smoke, or that shit you "puff" inthe colder climate? and waht do both indicate?
1993 Teg GS Automatic (sux)
Old 04-08-2003, 05:59 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
hey man, my old 320i could SCHOOL a civic.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 04-08-2003, 10:05 PM
GSR GSR is offline
all stock ecus run rich at wot, i wouldnt worry about it
white smoke in cold weather is just condensation. otherwise white smoke would mean your engine is burning oil. could be a number of things. worn rings, valve seals, bad head gasket, etc.
Old 04-11-2003, 12:27 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
Correction, White smoke means it is burning water, such as a leaking head gasket and such so water/condensation is getting into the combustion chamber
If it was blue smoke it would be rings, head gasket, valve seals....
If it would only smoke blue at startup then that would usally mean valve seals.... if it would only smoke white at startup that is usally leaky headgasket - leaking water.
Black smoke is not bad, dont worry about it it just means your car is running a little rich, thats better then running lean if you think about it.....
Kyle
[url=http://www.automotiveforums.com/vbulletin/showthread.php?
1995 Honda Civic EX
-Integra B18B1 LS engine
-Turbocharged
-Rear disk conversion
-Many mods
Cheak out my civic (cardomain)
Easly got 10k into this car with everything and it still looks like a POS
Old 04-13-2003, 03:47 PM
york2600 york2600 is offline
Send a message via AIM to york2600
Black = rich
White = oil (fried piston rings)
Green (right?) = coolant (blown head gasket)
Black can be fixed, but white and green are gonna cost you a lot.
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 04-13-2003, 07:12 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Blacks costing you a lot with the b20/vtec setup though ...
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 04-14-2003, 01:39 AM
I had the rich burning with the oil burning for lots of fun. It'll be worth it though. Just wait.
Old 04-14-2003, 02:40 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
its those damned potato chips u dropped in there when u were chaning the spark plugs...how many times i tell u? CAREFUL w/ those...ruffles are deadly
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 04-14-2003, 11:02 AM
Melt's Avatar
haha ... or maybe he didnt bolt the CAI on right the first time ... damn that install took us like the whole day cause we didnt know what we were doing
AF Bay Area Crew
