Pesky P0341 (cam sensor) code...
So how do I figure out this POS (94 LeSabre) to know if it's the crank sensor (again), the ICM, or actually the cam sensor?
Typical symptoms...after it gets fully warmed up the car sometimes acts like you're running out of gas, getting weaker and weaker, finally stalling or sometimes just stutters a couple times then stalls.
Re: Pesky P0341 (cam sensor) code...
Forget the cam sensor, it will not cause a stall! Evidently you replaced the crank sensor once before, what brand did you use? Early failure of off-brand (China/Mexico) sensors is not uncommon.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Not sure what the brand was, it was a year ago, maybe two. I want to say it was a Standard Motor part, but if I look at the Auto Value (where I got the part) website, it shows Delphi as the brand for crank position sensor.
