Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-09-2009, 06:55 PM
bowtieguy bowtieguy is offline
03 speedometer problem
anybody have any problems with their speedometer. got out of my Tahoe to run into the store came out and put the key in the ignition and before i cranked it over i noticed the speedo reading 85 mph while i was still parked. once i started driving the speedo appeared to be moving normally except 85 was now zero mph and as i started to speed up the needle moved up as well, till it pegged out on the little stop to the far right. anybody with a clue as to what has happened and what can be done to fix this? is this a common issue? if so what can be done and what can i expect to pay to get it working correctly again. i have enough problem keeping the law following me with lights flashing when my speedo is correct.
2002 Z71 ext. cab LT trim
badgeless
Rhino spray in liner
Stock for now, other than free mods
future plans (how far in the future depends on wallet)
Toyo Open Country M/T's
air intake (not sure which yet)
exhaust system (seems that Magna flow is the ticket)
Nelson tune
3 or 4 inch lift
Old 11-10-2009, 10:06 AM
j cAT j cAT is offline
Re: 03 speedometer problem
do you use your trip odometer?
since the speedometer peged out and you did not experience fuel shutdown [max speed 100MPH ] I suspect the dash circuit board damaged.
Old 11-10-2009, 09:23 PM
prconway prconway is offline
There was a court settlement on this problem.
Call this number for an update: 866-514-0405, or call your local dealer and ask them if they cover it. If you have an ongoing relationship with your dealer they may take care of it without any paperwork.
or perhaps "Obama Bailout 09" made all previous warranties and settlements null-and-void ???
Let us know if you have any luck.
Old 01-19-2010, 03:54 PM
john_6_2 john_6_2 is offline
I just got off the phone with GM the speedometer repair/repair reimburstment is still intact but it has a limit of 7 years or 75,000 miles. it GM bulitin number 07187.. Hope this info helps
Old 01-20-2010, 12:46 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You can remove the cluster and send it out to be repaired. The stepper motors that run the needles are of poor design for many 2002-2005 GM vehicles. I had the one in my Envoy repaired for $70 plus shipping through a place on eBay. They replace all the motors with new updated design. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
