Old 11-09-2009, 05:55 PM
super_man_736 super_man_736 is offline
Clicking noise
I have a 96 2.2 when i accelerate from a stop sign or light i hear a clicking sound coming from under the front of the car.
Old 11-09-2009, 10:03 PM
RahX RahX is offline
Re: Clicking noise
sounds like a bad cv axle
Old 11-11-2009, 03:25 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Clicking noise
Could be. A bad CV shaft will make a rapid popping noise (like a popcorn popper) which gets faster the faster the axle spins. They will typically only make noise while turning, but a very bad one could make straight-line noise too.
If it's only one pop, then it's more likely (1) a bad strut mount (car lifts up in front a bit and partially unloads the mount. (2) a bad lower control arm bushing letting the arm hit the subframe/engine cradle.
Have someone rock the car side to side and/or bounce the front up and down. If you can recreate the noise like that, use a long handled screwdriver as a stethoscope and listen for where the noise is the loudest. You may also be able to feel it pop, especially if it's a strut mount.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
