Old 11-09-2009, 04:41 PM
Kashmoney Kashmoney is offline
96 Lower Intake
Hello, I have a 1996 blazer and I just did the lower intake gasket on it. Put it all back together set the TDC and hanve it running but there is a knocking sounds now. Just wondering if it's a sensor that needs to be reset or something, any kind of help is appreciated. Thank you
Old 11-09-2009, 05:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 Lower Intake
Knocking is not good.
Is it deep inside engine?
Did the engine run with coolant in oil?
Coolant in oil will wipe out rod and main bearings.
Pull dip stick and see if oil has coolant in it.
On knocking noise remove one plug wire at a time with engine running and see if any change noise or remove noise.
If so rod bearing are shot.
Let us know what you find there.
MT
Old 11-09-2009, 06:35 PM
Re: 96 Lower Intake
It's putting a p0340 code
Old 11-10-2009, 08:25 AM
MT-2500's Avatar
AF - Advisor
Re: 96 Lower Intake
Code 340 is a camshaft position sensor or wiring problem.
Check is cylinder for rod or piston noise by pulling plug wire while running.
MT
