Old 11-09-2009, 03:40 PM
mebrown mebrown is offline
vibration when braking
I have a 1998 Ford Taurus . new rotors and pads all the way around. I recently starting experiencing a big time vibration when every I apply the brakes. I understand that this is an ongoing problem with this vehicle. Any thoughts or suggestions greatly appreciated
Old 11-09-2009, 10:13 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: vibration when braking
Did this vibration begin after replacing the brake rotors and pads, or were they changed in an attempt to remedy the vibration when braking? Did changing them out have any effect?
-Rod
Old 11-10-2009, 06:00 PM
I put everything on appx 12000 miles ago. About 5000 in i started having the same vibration as current. Had the mechanic where I work check everything over and resurface front rotors. He advised everything looked ok. Kind of got me puzzled.
Thanks for responding.
Old 11-11-2009, 09:44 PM
shorod's Avatar
SHO No Mo
Did resurfacing the rotors have any effect? Were the rotors out of round? Is the vibration felt only in the brake pedal or also in the steering wheel? If only in the brake pedal, the issue is probably in the rear rotors or drums depending on which system your car has in the rear. Did your mechanic friend torque the wheels back on using a torque wrench and a star pattern?
-Rod
Old 11-12-2009, 01:22 PM
Willyum Willyum is offline
mebrown,
Also in addition to what Rod has told, check to see if your rotors were machined too thin. Cheap and/or thin rotors will quickly warp again.
Old 11-14-2009, 07:34 AM
mwt47's Avatar
mwt47 mwt47 is offline
Check your tie rods.
The brakes have such a bad rap for this that people over look the tie rod ends.
It will cause the problem.
DId you "bed" the brakes when you installed them?
