Hedman Headers !!!
Greetings ... Just got off the phone w/ Chris Vandergriff , General Manager @ Hedman ... He stated that they would make long tube headers for the 302 in mild steel w/out ceramic coatings for
$ 500.00 a set ; but needs a production run of ten sets for his shop to tool up , plus a GT-Ra to fit or the other option is to communicate the modifications required to the GTS / 351 set-up ... His shop is in Atlanta ... hmmmm ... Any one near his shop ... I'm in northern Minnesota ... The other question to ask ourselves is there any significant differences in these cars that would need attention ; my car is from Texas & had different motor mounts ... Thanks / Paul W.
Re: Hedman Headers !!!
Put me down for a set! I can't help with the car in GA for fit checks, but I'd love to buy a set of headers.
Only need 8 more for the order.... Come on guys, these could add 10% power over those shorty headers. That's great performance increase for $500. Jerry
Jerry 1999 Panoz GT-RA |
Are you sure that there are issues with just using the 351 GTS headers??? You can install 351W heads on your 302 just fine with new push rods and perhaps rockers depending on the heads. I had an old set of aluminum 351W GT40 heads from the GTS that we put on my 302 GTRA. We also put on a carb so new manifold and distributor.
I would think the GTS headers would fit just fine. The 302 is about 1" narrower than the 351W, but there is enough slop in the clamps to make this up?? GTS headers are $1200 if I recall so $500 is a good deal. You may want to look at custom header shops in your area as it may be cost effective to modify your 302 headers to long tube. I had some custom headers made for a V8 for <$1k. Kevin |
What you guys really need is someone with a GTRA and a GTS to try fitting the GTS header to thier GTRA to see what issues occur. Price wise though Guys, $500 is a steal. It cost me around NZ$1,000 in materials and say 50 hours to fab up my system. If you do buy a set though, get them HPC (or similar) coated and you will get great service life from them. A question though for Hedman would be what primary pipe size, primary pipe length and collector size would they make for the 302 as this will have a big impact on performance and gains. Kel.
Kel M Panoz GTRA #17 New Zealand |
Paul, did he happen to indicate whether he has the 351 versions available without requiring a 10 unit order?
Jim McGovern ~ Building 289 Lemans Replica ~ '92 Mustang Coupe: 347ci / Carb Pictures |
Not trying to high jack this tread, but in the interest of header options: Gary Jones is working on a header system very much like Kel's 8 into 1. It is scheduled as a winter project. He'll be very interested in selling multiple sets to help absorb the prototyping and jig costs. No price has been determined, but it will be quite a bit more than $500 a set. Tom (cobrafang) and I are signed up and I think Tom's car will be used to do the first set. Go back and read Kel's report on the dyno results from his set up. WOW. Not only that but getting some heat and noise away from the driver is a big plus. Anyway this is another option to the Hedman unequal length long tubes as used on the GTS cars. If you want a set, let Gary know. Consumer demand is a powerful motivator and helps keep prices down
![]() I think there is a good chance the GTS headers would work on the GTRA cars, but they should be tried before purchase as was suggested. The driver's side is a real concern with the steering shaft. Mike |
![]() You will note that mixture was lean for the before run affecting low down torque. We did a couple of additional runs after the exhaust had been cut off (to free things up) and rejetted at this stage to correct the lean condition. Best we could get with Panoz/Ford shorty headers still fitted and exhaust cut off was 313hp/301ftlbs. As you can see above, fitment of the 8 into 1 system lifted power to 335hp/332ftlbs at the wheels and corrected to standard day temp/humidity conditions. We saw higher runs than this during tuning (343/340 as I recall) but above is last run with engine set up in "conservative" endurance tune that we did 6 hour with. As always these results occurred with a certain combination of parts, dont assume that you will get the same results as there may be parts of your combination that will hold power back. That aside, the 8 into 1 proved its worth on my engine. Kel.
How do you get a 8 to 1 set up
... Any pictures ; I just can't vision the geometry ... Very interesting !!! Might just go w/ the BBK equal tube shorty's ; they have dyno results of 8 to 15 hp ... still have all winter to think ... Thanks guys ; Paul W.
![]() One thing to consider re the BBK tuned shorties Paul, is what system were they comparing to when the quote an 8 - 15hp gain? Could be over a standard system. If this is the case you may not see this level of gain as you already have headers on the car. Kel.
We used a similar type crossover on my old GT-1 car. They really work well when properly designed with your engine. I don't think they would fit our cars but I placed a link to Dynatech so you can see an asphalt circle track set up. We didn't have a passenger foot well etc. like the Panoz.
Rich http://www.afabcorp.com/AFCO_Dynatec..._Code=pavement |
Put me down or a set. I know Cris very well, but didn't know he was affiliated with Hedman. I have Ford "Z" heads and I realize that the header may need a little modification to fit, but everything on a race car needs modification.
Craig
![]() Craig Wright PGTRA #21 '05 Ford GT '65 XKE (newest addition) |
[quote=Rich F;6063997]We used a similar type crossover on my old GT-1 car. They really work well when properly designed with your engine. I don't think they would fit our cars but I placed a link to Dynatech so you can see an asphalt circle track set up. We didn't have a passenger foot well etc. like the Panoz.
Rich /quote] Can be done Rich as the system I have put in is modelled off Transam/GT1 style systems. The trick is getting the lengths the same for both sides of the car while at the same time bringing the drivers side across to merge with the passengers side. We were able to achieve this at pretty much the tuned legths that we had calculated out. Just takes a lot of time and a few beers..........
Craig
Greetings ... Kel , what mufflers did you install ???
Are the linear mufflers that came on these cars part of the problem ??? I thought they were high flow ... thanks / Paul W. |
We have a 95db limit over here and I have not been flagged as yet. The track that I run on has the sound meter on the opposite side to my exhaust so this may be getting us by. The car is still loudish inside (even with passenger side window fitted) but not so bad from the sde of the track. Certainly very distinctive note though being a single outlet system. It will be interesting to see how it sounds with the 347 fitted as this engine will have quite a bit more compression so will have a bit more of a "bark" I expect. The mufflers that were fitted to the system that came on my car were very ugly. They were extremely heavy and of the "punched in louvre type" where the gas flow is disturbed by and restricted by the louvers. Even though there is a lot more primary and secondary pipe in the system I have fitted now, I think it would be lighter than what I took off. This is mainly due to only having one exhaust down the side of the car and elimination of the heavy mufflers that were fitted. Kel.
